diesel fuel pressure to start
Hi all,
Have an odd problem with a C220 Diesel, won't start when cold unless easy start is sprayed into inlet, it will start and then run absolutley fine for hours - But once stopped will not re-start even when warmed up. Believe its fuel pressure related just wondered if anyone knows what the fuel pressure should be when cranking? Have check and its only 50bar don't beleive this is high enough. Have already changed low pressure pump (On front of head). Not sure what to change next, any ideas? Thanks Wayne |
