Coolant - Special or Generic?
Does my '96 C220 require some special coolant that only Mercedes has at some outrageous price or is there soething that I pick up at Lordco or WalMart?
RE: Coolant - Special or Generic?
Mercedes does have a special coolant. Valvolene's Zerex G-05 is the exact same formula and is approved by MBZ. Available at CarQuest.
Suitable for aluminium engines is a prerequisite ...
however I suggest that you play safe and only use an MB approved specification. The wrong spec can cause major damage. Stuart. |
Buy premixed or use distilled water too. Diluting with normal tap water is hard on your system due to build-up and possible corrosion
Thanks guys. I'll stick with the MB stuff, it's not as expensive as I thought.
| All times are GMT -5. The time now is 07:31 AM. |
