Compression Pressure
Does anybody know the normal cylinder compression pressure for an R129 5.0L V8 in psi?
RE: Compression Pressure
tolerance when new: 13.5 to 15.5 bar.
limit value is: 8.5 bar permissible difference between individual cylinders: 1.5 bar now, just convert it to PSI. maybe about roughly 14.5 psi to 1 bar. |
Maraming Salamat Sleepwalker!
I presume limit value of 8.5 Bar is lowest value permissible otherwise an overhaul is required? My 1994 R129 is reading 12 bar - is that normal? |
walang anuman. basta pag may kailangan ka, just post.
very normal and ideal. for as long as the deviation from one cylinder to another is not too far. |
| All times are GMT -5. The time now is 10:04 AM. |
