code p0600 and p0705...can not shift
Please help....got code: P0705 and P0600 and having trouble shifting gears.[:@]
Read code and wanted to know if anyone had this problem, how to resolve and cost. Thanks all. |
RE: code p0600 and p0705...can not shift
P0600 is a "Serial Comms link"
P0705 is a "Transmission Range Sensor Circuit Malfunction" Looks as though something must be wrong with the PRNDL (driver gear selection) electrical connections / comms You don't state age mileage history etc. Corrosion / water ingress? Look VERY carefully around connection pins. |
Thanks for your reply. Had the car checked and replaced the gear shifter, reset the codes...alls fine.
Just bought the 2001 E430 with 77760 miles a few weeks ago..... I don't think I spilled anything by the shifter but that is the symptom according to the mechanic and other MB forums. |
