climate control lighting
RE: climate control lighting
If you turn on the lights, both the HVAC and radio and dash, console lights, will light up. You need a pair of radion pullers, either form your dealer of eBay to get the unit out and replace the bulb, as I assume it is replaceable?
Yes it does light up.
Your backlight bulb is most likely blown.
You need to get the removal tools to pop it out. (Very inexpensive tools)
See Picture
Once you slide out the unit, unplug connectors 2 & 3 then you should be able to see the bulb to change.
[IMG]local://upfiles/5574/0A59056D777E4AE3A9887F519103B4AA.jpg[/IMG]
See Picture
