Check Bulb
I have a 2000 E430 and the "CHECK BULB" light went on unnder "MALFUNCTIONS". The problem is that I cant find the burnt bulb?, they all seem to be working, any suggestions.
RE: Check Bulb
Try looking at booth tail light housing and clean up the terminal and wiring connections.
For some reason small debris make it to the connections and shorted the connection even when all your lights are on. |
RE: Check Bulb
ORIGINAL: rhbjwa Try looking at booth tail light housing and clean up the terminal and wiring connections. For some reason small debris make it to the connections and shorted the connection even when all your lights are on. yeah...i did it once... and it's okay |
