-   -   Car won't start. Need help! (https://mercedesforum.com/forum/general-tech-5/car-wont-start-need-help-53671/)
termigator Aug 6, 2013 07:43 AM
I have a 95' E320 that won't start. When I turn the key, nothing happens. engine and battery lights are on and the battery seems fine, but nothing happens. There is a humming/buzzing sound coming from the general area around the left AC vent and light switch knob. Any help/suggestions would be greatly appreciated!
go-part Aug 21, 2013 09:07 PM
Have you checked all of your fuses and relays?
Have you had your battery and starter tested?
http://www.ifitjams.com/starting.htm
BigSkyBenz Sep 22, 2013 04:51 AM
Hello! I have faced the same problem couple of days ago. Like you when I turned the key it just switched on the lights and else nothing happen. Then I thoroughly read the diagnostic flow chart and doubled check the fuses. I checked the battery as well and happily this was okay. I recommend you to read the starter diagnostic flowchart.
http://www.ifitjams.com/start.gif
