c200 boiling
Old Jul 8, 2007 | 03:59 AM
Year1998C200's Avatar
Default c200 boiling
now my c200 is always heating up at about 100degrees weneva am on traffic.the water boils at this point.i also noticed that when the fan is on it rotates kinda sluggish. however when am driving the car over 100kms on a highwaythe temparature level drops drastically. how can i ecrease temperature and how can i boost the fan
please advice
Old Jul 8, 2007 | 12:54 PM
wmercer's Avatar
Default RE: c200 boiling
It is ok for Benz cars to indicate 100degree C on the engine temp gauge if everything with the engine is working ok. It is not normal for it to overheat/boil over at that temp. Consider a cooling system flush and refill with good quality antifreeze at a mixture of 50/50 antifreeze/water. While doing this, ensure no leaks in the cooling system. Any repair garage can do this for you. Jiffy Lube and other oil change places also can do this. If doing it yourself, consider:http://www.alldatadiy.com/ for maintenance information. Worth the annual fee.
Old Jul 10, 2007 | 09:08 AM
thanks bill, will try that and let u know
Old Jul 17, 2007 | 11:42 AM
irantehran's Avatar
you most likly not circulating the coolent good at idle, feel the temp of the upper and lower hose by hand if diffrent you may have a clogge radiator check your radiator cap check fan clutch if you can stop it by hand or an object at idle when engine is hot is not good, when you drive the air flow cools your radiator thats why you are better ,
check your head gasket for problem
L500SAF
Oct 7, 2011 10:35 PM
Year1998C200
Jul 15, 2007 04:34 AM
parbreaker
Jun 26, 2006 05:07 AM
Heli
Aug 21, 2005 12:28 AM
