C-250 D 1995 aut. gear problem.need help?
Old Jan 5, 2006 | 09:46 PM
eivin's Avatar
Default C-250 D 1995 aut. gear problem.need help?
Hi
Just got the car and there is a problem with the aut.gear box.
When i start driving it runs trogh 1. 2. 3. and 4. gear before 40 mph ??
I have to put the pedal to chick down switch before it goes down to (only) 3. gear ?
It is soo slooow so I have to by manual changing the gears.
It has electronic trottle control and one wire from the trottle is going down to the automatic gear box together with 2 vacum tubes (from control box linked to the trottle wire), this lok all ok to me.
Any ideas enyone ?
Old Jan 5, 2006 | 11:22 PM
sleepwalker's Avatar
Default RE: C-250 D 1995 aut. gear problem.need help?
the control cable which connects from accelrator to trans might be too tightly adjusted. loosen it a little if it is.
high modulating pressure can cause that also.
Old Jan 6, 2006 | 12:24 PM
eivin's Avatar
Hi
But the wire can not be adjusted ? it is just on, and off ?
high modulating pressure ? is it the governor valve placed inside the transm. ?
EIvin
Old Jan 6, 2006 | 10:52 PM
it can be adjusted from the linkage.
high mod pres = low shift pressure.
the governor serves as the valve itself opening and closing depending on rotation speed.
sp1249
Aug 24, 2011 11:04 PM
sp1249
Apr 16, 2010 02:37 AM
qghauri
Jul 7, 2006 05:20 PM
qghauri
Dec 5, 2005 02:41 AM
