BRAKE PAD...VISIT WORKSHOP..
Hello Forum
My W215 CL500 came up with the message BRAKE PAD - VISIT WORKSHOP on the MFD a few days ago - SO assumed the pads and Discs (Rotors) needed changing - I decided to do this task myself. Surely enough - once removed that Fronts pads and Discs (Rotors) had seen better days - so replaced, installing a New sensor. The rears are fine. AnywayI still get the message BRAKE PAD VISIT WORKSHOP on the MFD - so I replaced the Rear Sensor as well - and still there. Any pointers what i could check - BTW - also plugged her into STAR - NO Faults anywhere! Help Nik (UK) |
RE: BRAKE PAD...VISIT WORKSHOP..
Brake reservoir fluid level OK?
Changed sensor on BOTH front brakes or does your vehicle only have it on one side (cost saving!) Stuart |
Yup - Brake Fluid Level OK - Sensors are one on each axle (one in Front and one in Rear) changed both of those - This is driving me crazy!
Sure that there is only one sensor per axle?
Circuit is a simple loop. The sensor wire simply gets cut by the rotor. Sometimes handbrake ON is also part of the circuit. Sure you have got the brake OFF? Stuart |
maybe make sure sensor is pushed all the way into the connection for the sensor. sometimes it goes in a little tight. or the new sensor wire is broken?
Hey guys
I have replaced the sensors with 2 sets of new ones can confirm that ther is only one on each axle, and confirm that parking brake is NOT on I am wondering if there is breakage in the wiring somewhere - will check soon again thanks Nik |
Chassis221 may be spot on. Were the sensors Genuine MB or some proprietary after market look alike part? Maybe the connectors have not gone/been pushed pushed fully home. As I stated the circuit is a simple loop so it should be relatively easy to do a bit of continuity testing. Stuart |
The Sensors are Genuine MB part - I also tried pushing as far as I could with hand - I will check for contunuity! - its a real shame a little issue like this takes so much time.
Again, thanks for your input and its forums like this this that give a better insite into issues Regards Nik |
Do you have to replace the sensors during every change? And where can I find them?
some mercsneed basic setting of brake pads after replacing on diagnstic tool
