-   -   Bosch spark plugs ok? (https://mercedesforum.com/forum/general-tech-5/bosch-spark-plugs-ok-8767/)
inssane3gt Jan 14, 2006 05:11 AM
2000 E320
I getting prepared to change the (12) spark plugs. 75k on odometer. Autozone has Bosch spark plugs for my vehicle. Bosch a good move?
C280 wizard Jan 14, 2006 10:45 AM
RE: Bosch spark plugs ok?
I have Bosch plugs in both my Mercedes, my 99 C280, 12 plugs also, came with Bosch Plugs when I bought the cr (pre owned). Last weekend I changed the plugs in my 450SLC (only 8) and used Bosch Plats. The Pats fire a bit hotter then a non plat, but I don't think this will be a problem in the 450SLC. My son has Bosc Pat 4's in is 96 Acura. So what's my point, I think Bosch plugs are a great product and will outlast most other brands
Lugnut Jan 14, 2006 03:36 PM
It doesn't matter. They're all the same.
Buy copper ones. Don't waste your money on platinums. Copper plugs perform better and are dirt cheap in comparison to platinums. You need to change copper more often. About every 30K to 40K miles.
Be sure to put some anti-seize on the threads. It will keep them from fusing to the aluminum heads.
teddybear Jan 14, 2006 06:16 PM
I agree that Platinums are not worth the extra money.
I have tried Bosch. Beru & NGK in my R129 & W124 s and have found NGK the best in that they have good wear characteristics and are excellent for anti-fouling on older engines. The idle is noticebly smoother and marginally faster on NKG s.
inssane3gt Jan 14, 2006 08:52 PM
Good advice. Thanks
GermanStar Jan 15, 2006 02:16 AM
Your car came with Bosch plugs from the factory, so I suppose that's a recommendation.
jud149 Jan 15, 2006 12:07 PM
I would go with the Bosch 4's. Platinum plugs last longer since they are resistant to fouling type crap sticking to them. This is why most cars come with them today as manufacturers want to reduce maintenance. These 4's will last 100k miles if the engine is in good condition. Changing plugs every 30k or so is ludicrous considering the technology we have today. Actually the Bosch 4's have been proven in independent tests to improve gas mileage and increase horsepower. I've read that Bosch is too conservative a company to make these claims.
BikerDrew Jan 15, 2006 02:06 PM
I have 95K on mine, they are going away this week and will be replaced with the Bosch 4's. My car still runs smooth on the original plugs!
inssane3gt Jan 15, 2006 03:17 PM
What about this one:
http://replacement.autopartswarehous...20Plug&dp=true
(The first plug on the page, it's the only Bosch one there)
Lugnut Jan 15, 2006 04:32 PM
Platinum plugs provide a less powerful spark at the same gap than copper. That's why Bosch doesn't make such a ludicrous claim as the platinum increases horsepower.
If you use platinum, make sure they are the kind without platinum buttons. They'll fall off into the combustion chamber long before 100K miles.
None of you guys are stressing the use of anti-seize. With just about every M-B using aluminum head(s), you need anti-seize if you ever plan to remove spark plugs after 100K miles without removing part of the head(s) along with the plugs.
Most of you guys are putting way too much importance on spark plug brands. You sound silly as ****.
