Ball Joints
Got an 84 300D turbo that has a major creak in the right front when bounced or under normal driving. I've been told this is likely to be a ball joint. Does that make sense? Is that something the average DIYer can do, is this part of normal lube?
Thanks |
RE: Ball Joints
KY, That does seem reasonable but there are no grease fittings on that MB. You can change it but you need to rent or borrow a tool to compress the spring. Don't do it without that. It is under great pressure and it will hurt you.
