-   -   Another Glow plug problem (https://mercedesforum.com/forum/general-tech-5/another-glow-plug-problem-31437/)
sphinx_57 Aug 21, 2008 10:17 PM
Problem- When I go to start the car the glow plug light does not come on and the car is hard to start. If I try again it will only come on for a few seconds.
The Car- 82 mercedes 240d
So I have read threw some threads and this is what I have done. I changed the glow plugs about 9 months ago and it seemed to work fine until the last month. Only put about 4k miles on the car. I have checked the relay and it makes a click when I first turn the key and about 15 seconds later makes another click. I put the multi meter to it and it seems to be put voltage across until the second click. Any ideas what this could be?
sphinx_57 Aug 23, 2008 06:28 PM
RE: Another Glow plug problem
No ideas, I have one what if when I turn the car over once or twice it heats the glow plugs alittle. That would explain why the light comes on for a short time after I try to start the car.
sphinx_57 Aug 28, 2008 09:03 PM
bump
andry Aug 29, 2008 07:46 AM
any help, someone please?
mbtech215 Sep 11, 2008 05:57 PM
glow plug module on the left front fender under hood ,they always go bad you may want to alos check the glow plugs again to verify they are ok with a test light put to 12 volts then probe every pin on connector for glow plugs to verify good ground
