Alarm goes off when battery changed
Old Apr 1, 2007 | 03:22 PM
Sholix's Avatar
Default Alarm goes off when battery changed
I'm feeling really dumb here. I've searched for this but didn't come up with anything so I guess I'm the only one around with this simpletons' problem.
You see whenever I remove and replace the battery from my older model (1997) Mercedes E320, the factory installed alarm goes off. Then the car locks up and wont start.
What am I doing wrong?
Is there a secret or series of steps I should be taking when I remove and then replace the battery?
Thanks from a Damsel-in-Distress.[&o]
Old Apr 2, 2007 | 06:58 PM
stahlkrieger's Avatar
Default RE: Alarm goes off when battery changed
When changing a battery hook up a charger to THE LEADS before removing the battery. Place new battery in its place hook up the cables then remove the charger. You will never lose power to the car and avoid any of the usual problems, ie radio code, alarm....etc.
Michael
P.S. You joined on April fools day.....But I ain't foolin....the charger idea works great!
Old Apr 3, 2007 | 01:35 PM
Sholix's Avatar
I hadn't noticed it was April Fools' Day.[>:]
Thank you for responding. I never would've thought of trying to change the battery that way.
I'll give it a try anad let you know the outcome.
Old Apr 5, 2007 | 07:15 AM
Shan's Avatar
Have you tried using your remote to open close and open the door locks after you changed the battery and the doors get locked with the alarm going off?
Shan.
MLKazza
Apr 8, 2010 03:06 PM
inkpusher
Feb 15, 2010 05:06 PM
barebackmolly
Mercedes A Class
Dec 18, 2009 11:25 AM
mosinoi
Feb 18, 2009 07:20 PM
fastmike99
Sep 2, 2006 04:24 AM
