Air Powered Locks on '89 300SE dont work
Hello,
When I was removing some things out of the trunk of my 1989 Mercedes 300SE a metal hook or something cuaght and cracked one of the yellow wires running through the side of the trunk, I thought it was a brake light or something till I looked inside and and nothing was in there, but when I went to lock my doors I noticed that only the door you lock now works and you have to push the rest of the locks down to get them to lock. I tapped the yellow hose back and did a really good job so that no air would flow out of it but the door locks still don't work. Any idea's how to get them to work or do I need to have a shop fix the lock system. Thanks, Mike |
RE: Air Powered Locks on '89 300SE dont work
Fixed it , I just remembered they dont have Air locks and it;s all power and I blew the fuse.
look at other end of hose.. if ya pulled end near you or where you caught it loose, theres a good chance it got pulled loose where it connects
