-   -   98 clk320 conductor replacement (https://mercedesforum.com/forum/general-tech-5/98-clk320-conductor-replacement-3497/)
slamdbus Jan 16, 2005 06:32 PM
My name is Robb and Im in Seattle. I replaced my conductor plate in a 722.6
trans, along with the coupler for the harness. I am getting hard engagement of forward and reverse
and the trans is in limp mode with a check engine light. Every think went together well but it does not
work now, atf level is good and proper for trans. Do I need to delete error codes? I do not own diagnostics
for this car, can you help?
sleepwalker Jan 16, 2005 11:22 PM
RE: 98 clk320 conductor replacement
the electrohydraulic valve unit and the electronic traction control unit must have a matching number.
try disconnecting/connecting the control unit to reset.
if the problem is no longer present, it not run in emergency mode.
slamdbus Jan 16, 2005 11:35 PM
Thankyou for your reply sleepwalker. can I disconnect at the coupler? or at the ecm?
sleepwalker Jan 16, 2005 11:38 PM
ETC. Electronic Traction Control module.
