94 E320 ACC Fan Irratic After Evaporator Replacement
Old Jan 13, 2007 | 01:08 AM
olin123's Avatar
Default 94 E320 ACC Fan Irratic After Evaporator Replacement
Well, I just completed the fun job of replacing the evaporator. Thanks to all the notes I did it in 3-4 days working 6-8 hours a day. The only non-functioning piece before the job was the A/C (of course).
After finishing the job, I noticed that the ignition switch was much harder to turn all the way CCW (position 0). Note: ignition switch was not removed for this job since I lowered the steering column. And the gear shifter lock would not dislodge (yes brake depressed and ign on). I have gotten around this by lossening the cable to the lock and manually disengaging by pulling the cable and tensioning the wire everytime I want out of park.
The other issue is my fan. With the car cranked and the ACC off, I can turn the fan on by starting on HI fan setting. But it seems to slow down over time. Turn to Auto and the fan barely turns like it is on stage 1. I turn the ignition off to investigate w/o burning gas and turn only to the "on" (position 2) all functions as it should. Meaning that I can hear the fan ramp up through the stages as I turn the dial futher away from ambient temperature.
It should be noted also that the flaps seem to work just fine. If I turn on defrost, windshield vents are open. If I turn the EC button on and dial to 85, heater vents open. Turn dial to 65 and center vents open and temperatur begins to cool. Temperature doesn't seem to be as hot either when the car is cranked, but more heat is delivered when it is shut off and in position 2. Seems like modulating valve is not operating as it should.
Lastly, my SRS light will come on for about 5-10 seconds and go off early in my commute.
I have read some of the archieves, but I thought I might have a bit of a special case here, so please help me out if you want to chime in. Some of the things I gathered from the posts are:
1) Ignition switch - could explain shifter problem - maybe the SRS
2) Fan Regulator - doubt it since all functions normally when car is not running
3) ?????
There may be a reason why they tell you to remove ignition switch that I was not aware of. I did reconnect the transmission lock cable to the switch.
Olin Brimberry[/align]
rsvensson
Feb 20, 2014 09:26 PM
axe_360
Mar 28, 2008 12:42 AM
stuartwood
Jul 20, 2007 05:56 PM
8092400e
Nov 9, 2006 03:53 AM
shadetree
Sep 27, 2005 12:53 AM
