92 SL500 Transmission just quit? Sorta
Old Mar 7, 2008 | 01:09 AM
Cudadan's Avatar
Default 92 SL500 Transmission just quit? Sorta
Hello,
I just bought a 92 SL500 at the Palm Springs auction. Very nice car with 116,000 Miles. Appears to be well maintained and cared for. Any Way i drove it about 30 miles all seamed fine. Then accelerating from a stop light the car made a twang sound and lost all forward or rear ward motion. The trans seams to work only i can hear something in the rear that sounds stripped. The Drive shaft looks fine. The car will roll if in Park as well.
Any ideas what happened and what will be needed to fix it?
Dan
Old Mar 8, 2008 | 05:59 AM
wmercer's Avatar
Default RE: 92 SL500 Transmission just quit? Sorta
If driveshaft turns while transmission is in gear, symptoms lean toward a rear differential internal failure or a axle breakage. Suggest having car towed to a repair shop for further diagnosis.
Old Mar 8, 2008 | 09:21 AM
Cudadan's Avatar
Hi, and thanks for the input.
The rear end is fine, It spins the driveshaft right through to the yolk in the trans. Even in park. Not good eh!
I will pull the trans out Sunday and take to the local trans shop for repairs.
Must be a freak break as no one seems to know what failed.
Dan
Old Mar 8, 2008 | 09:23 AM
Cudadan's Avatar
Any one know of good sources for used transmission parts? Or better yet What years and models carry the same transmission?
Dan
Old Mar 9, 2008 | 09:37 AM
MASTERBENZ's Avatar
Banned
Get it rebuilt...
take care,
-mar-
Old Mar 9, 2008 | 08:30 PM
wmercer's Avatar
agree. get the trans rebuilt. I have found when I had to rebuild my trans, it really is just the best solution to havethe trans shop reomove, rebuild, replace the trans. Keep away from AAMCO (they hurt my first trans rebuild) and other chain stores, go with a local you have talked to and has many cars/trucks parked outside, which means, they are really good. Keep us informed.
Liverhuyen
Aug 3, 2014 08:58 AM
Dobbes
Mar 14, 2012 01:31 AM
UncleMarkProductions
Jan 24, 2008 07:55 PM
harlista
Jan 4, 2006 10:12 PM
herbman
Jan 28, 2004 09:01 PM
