-   -   722.9 gearbox coding (https://mercedesforum.com/forum/general-tech-5/722-9-gearbox-coding-68859/)
Sir Fred Funk Mar 19, 2026 06:32 AM
Hello everyone
I have a 2014 E Class 220 Cdi convertable. I bought it knowing that it needed a replacement gearbox. The guy I bought it from told me that the gearbox needs to be coded to the car but the original gearbox isn't available. For the price I paid for it I said to myself ?no problem?. He asked If I knew someone that could do it....I told him ?yeah?. I bought a used gearbox'... the guy I bought it from asked if I knew that the gearbox requires coding to the car. I told him ?yeah,,,no worries?
You all know where this is going......
The worries started when I was told that I needed parts from the original gearbox. I asked friend of a friend and he told me that I may have to get gearbox parts that have been 'virginised' but there's no guarantee that they will work as the 2014 gearbox for my car is a Gen 4. To guarantee that I will be able to code the replacement gearbox to the car I would have to buy a brand new gearbox control unit and a controller unit . I don't want to repeat how much it he said it could cost.
But ChatGPT tells me a different story...I asked...
Hi Chat, I need to replace the original automatic gearbox in a 2014 E Class 220Cdi for a reconditioned gearbox. My problem is that I was told I need the original gearbox to code the replacement but the original isn't available.
CharGPT replied
You do NOT need the original gearbox to code a replacement on a Mercedes-Benz C207 E-Class Coupe with the Mercedes-Benz 722.9 transmission. ?
That?s a very common misunderstanding.
Let me explain how it actually works.
How coding works on the 722.9
On the Mercedes-Benz 722.9 transmission, the control unit (called VGS) is inside the transmission conductor plate.
When installing a replacement gearbox you normally:
1️⃣ Install the gearbox
2️⃣ Connect diagnostic tool
3️⃣ SCN code the VGS module to the car
SCN coding uses the VIN from the car, not the old gearbox.
So the original gearbox is not required.
Why some garages say they need the old gearbox
Sometimes they mean one of these things:
1️⃣ Transfer the conductor plate
Some rebuilders reuse the old conductor plate/TCU so the car doesn't need coding.
But if the old gearbox is gone, the replacement unit will just need coding with a diagnostic tool.
2️⃣ They want the gearbox variant number
Example:
722.908
This tells them which mechanical version to install.
But your VIN already tells this.
3️⃣ They are avoiding SCN coding
Proper coding requires:
  • Mercedes-Benz Xentry Diagnostics
  • Online SCN access
Some smaller garages don?t have this.
Correct process for installing a replacement
A proper installation on your Mercedes-Benz C207 E-Class Coupe should be:
1️⃣ Install rebuilt 722.908 gearbox
2️⃣ Connect Mercedes-Benz Xentry Diagnostics
3️⃣ Perform SCN coding
4️⃣ Reset transmission adaptations
5️⃣ Perform adaptation drive
Total coding time: 10?20 minutes.
Important thing when buying the gearbox
Make sure the replacement is:
  • 722.908 variant
  • from a diesel OM651 car
  • with VGS3 electronics
Otherwise coding may fail.
What happens if it isn?t coded
If the gearbox is installed but not coded, you may get:
  • stuck in limp mode
  • harsh shifting
  • gear display errors
  • fault codes
Bottom line:
You only need your VIN, not the original gearbox, to code a replacement Mercedes-Benz 722.9 transmission.
One more important thing (this surprises many people):
About 30?40% of reconditioned 722.9 gearboxes sold in the UK are actually the wrong internal variant for OM651 cars.
Tips for your gearbox swap & coding
  1. Talk to them first about ?SCN coding / gearbox VIN coding? specifically ? not just mechanical fitment. Many general transmission shops fit the box but won?t perform SCN programming unless they have Mercedes level diagnostic tools.
  2. If a specialist removes your original VGS/TCU and reuses or transfers the coding, they might reduce the need for official SCN work ? but if it?s a replacement unit, you?ll usually still need proper coding.
  3. Some companies offer TCU reprogramming or cloning services (e.g., Pelican Diagnostics or similar online services) that can ?clone? your original data onto the replacement before it?s fitted ? sometimes saving dealer coding.
What are my options? Many thanks in advance, Fred.
