500 SEL oil change question
Old Dec 25, 2005 | 04:19 PM
nightvision's Avatar
Default 500 SEL oil change question
Hi all,
I'm doing a little work on my mother's 1985 500 SEL. I like to change the oil. Just bought the oil filter and it's not a screw in type, it's a canister lype. I never install one of these so let me ask a few simple questions.
I believe I've located the oil filter on the left side of the engine. The oil seems to be encase in the metal canister housing. I'm assuming all I have to do is remove the screw on top and then remove the oil filter and replace a new one. I'm curious to know if there are any surprises that I should be aware of when openning the canister housing. Are there any spring under tension that I should be aware of. Any, suggestion would be appreciated. I just don't want to mess up this simple task.
Old Dec 25, 2005 | 10:05 PM
MB/TECHMAN's Avatar
Default RE: 500 SEL oil change question
nothing to it ..just take bolt out ..nothings going to jump out at you
Old Dec 25, 2005 | 10:49 PM
Lugnut's Avatar
Huh? You're not going to tell him about that oily gremlin that jumps out and bites you on your face?
stejay
Jul 4, 2011 08:28 PM
500sel mark
May 6, 2010 03:20 PM
sdmfer
Jun 18, 2007 10:09 AM
paulmiller869
Feb 11, 2007 01:54 AM
graybmg
Jan 1, 2005 02:38 PM
