380sel and 380sl same engine???
i'm was going to swap a 380sl engine with a 380sel 1983 will this work thanks Erik
RE: 380sel and 380sl same engine???
Should be, however the plumbing for intake and exhaust as well as throttle cables etc may well be differentdue to the different configurations of the coupe and sedans. Make sure to hold ontoall that stuff from the engine to be swapped. It might be a good time to check if the engine you are swapping in has the single row or double row cam chains. If it still has the single row cam chains, now would bea great time to do the double row upgrade.[/align][/align]Regards,[/align][/align]Will[/align]
where do i get the upgrade chain and so forth thanks Erik
