300 SEL no spark
Hi all,
New to the club. I've got a problem with a Mercedes 300 SEL - its not firing/no spark. I have checked all the obvious any suggestions? Thanks, Aido |
RE: 300 SEL no spark
Sorry to be a little more clear about my problem.
On the coil there is two pins no. 1 and no. 15 both of which are live. I'd expect one to be negative. When I try and turn the engine over there is no spark coming from the HT leads. Suggestions? Or where possible a wiring diagram ;) Thanks. |
Nobody knows much on this site I can tell you that. I havea '67 250 S, and I have just changed over to electronic ignition from points. You don't say what year your car is, and I don't know if it's electronic or not; however ,there should be 12 volts going to the coil prior to starting, and after you turn the key8 volts. Could be a bad coil. Use a volt meter to check voltage. hope this helps some. Dave.
| All times are GMT -5. The time now is 10:18 AM. |
