-   -   260e troubleshooting (https://mercedesforum.com/forum/general-tech-5/260e-troubleshooting-13436/)
jetdoc Aug 5, 2006 07:11 PM
I have several issues for you experts out there. #1) The fuel gauge indicator is acting erratic as I drive. Does any one have the electrical schematic for the fuel indicator system?
#2) It's very hot here in Kansas and the A/C is blowing cold out the dash vents and HOT out the over dash (defrost) vents. HELP!
#3) I am in need of a PDF of the owners manual, but http://www.mbusa.com/owners/vehicle_...ers_manual.jsp says that mine is not available from their sight. can any one help with this one?
Thanks in advance!
Jetdoc.
jetdoc Aug 11, 2006 08:54 AM
RE: 260e troubleshooting
OK, its been 5 HOT days and I have had no reply! I was hoping to have some guidance by Saturday as it is my day off and the only chance I have to work on these problems in the early morning, before we get baked. Seems sad, 18 hits but 0 replys.
jmang09 Aug 11, 2006 10:44 AM
what year 260? I might have a manual for you.
j-mang
jetdoc Aug 11, 2006 07:00 PM
it's a 1989 260E (I should have put that in in the 1st place)
BlueSilver Aug 11, 2006 08:19 PM
Jetdoc.
More than one under dash problem? Not a clue, but I'll try to help find a manual on the car.
Charles
jetdoc Aug 12, 2006 08:41 PM
as an addendum to the HOT air from the windshield vents, I did some troubleshooting today and found that the solenoid (water shut off) valve, (next to the battery) seams to be functioning correctly, (extended to block water when powered). So how else can the hot water be passing thru?
knobbycva Mar 24, 2010 01:39 PM
AC/heat
solenoid (water shut off) disconnect wires to it and disconnect the AUX water pump on passenger side wheel well then see if that cures your problem but I think it will be the climate control unit get one at a scrap yard find a late model one
