2007 C230 oil change
Any tips on how to change oil on a 2007 C230? I am stumped; I think I found the oil filter housing, (looks like a BMW 3 series; upright filter housing at the front of the engine on the driver's side) but I don't see a drain plug. I removed the plastic undertray.
Also. is there a source for a service manual for this car; I don't see a manual listed by Bentley or Chilton. Thanks |
RE: 2007 C230 oil change
you do realise that by doing your own oil change on a2007 model you will invalidate your warrenty.
but if you really must I would sugest getting a vacuum kit from somewhere and suck the oil out of the dipstick tube. If your in the uk screwfix direct do one for about £40. |
how often should the oil change be made?
