2003 SL500 stuck in park
Old Aug 14, 2007 | 04:28 PM
dhamley's Avatar
Default 2003 SL500 stuck in park
Hello,
My 2003 SL500 w/ 26,000 miles started getting a little stiff when pulling out of park. Then without warning it is now stuck in park. Checked top to make sure its completely up / down foot on brake etc. ?????
Old Aug 14, 2007 | 05:20 PM
MBTECHINFO's Avatar
Default RE: 2003 SL500 stuck in park
Have you spilt anything into the shifter? This is a common symtom referred to as "pepsi syndrom"
I would first check the stop lamp switch which has 2 internal switches. One is for the lights, the other for brake shifter interlock. Chances are that it is the shifter itself. The repairs will have to be performed by a dealer or somebody with access to a MB SDS machine to unlock the transport protection of the new unit. You will likely have to have the vehicle towed in unless by chance it will come out of park. I don'tbelieve that there is an accesible emergency park release on this shifter. Sorry for the news.
Old Aug 14, 2007 | 06:11 PM
dhamley's Avatar
Thank you for your quick reply.
No nothing has been spilt in that area, let along anywhere else. I have checked the stop lamp switch, when the shifter interlock connection is removed from the switch, natually it errors on screen as a "Brake System Malfunction" but reconnected it clears the error and reads fine. I can hear the mechanism inside the shifting gate move as I press on the brake pedal. Additionally while the switch was out I checked the full throw of the plunger without luck.
Thanks anyways.
dhamley
Old Aug 14, 2007 | 07:14 PM
MBTECHINFO's Avatar
Well, I guess you are in need of a shifter. Shouldn't be too bad though in comparison to many mercedes repairs. I think you can get out around $1000 or less for the repair. Remember that dealers can often reduce the repair bill by 10-15% without hastle if you tell them you are pressed on cash and/or have a good service writer.
starchild
Jan 27, 2026 06:10 AM
foto1
Dec 15, 2014 10:58 AM
liaostella
Jul 20, 2012 10:36 PM
msnijhar
May 25, 2005 01:18 AM
