2002 clk 430 not starting
Old Aug 29, 2007 | 10:03 AM
Damcgreg's Avatar
Default 2002 clk 430 not starting
Any suggestions here are appreciated -
Woke up this morning, and car would not start. When turning the key - All instrument panels work, all digital features, etc. But when turning farther to start engine - it would not turn over. First MB, but as far as the batteries work, I don't think this could even be battery related....
thanks again
Old Sep 1, 2007 | 02:42 AM
snanceki's Avatar
Default RE: 2002 clk 430 not starting
Tried your spare key?
Do fascia warning lights etc.remain illuminated when you turn key to "Start" position? Try increasing load by putting the headlamps on also. If the headlights dim significantly when trying to "start" then I suspect your battery.
If headlights remain bright but basically nothing else happens then possible that starter solemoid connection is loose, disconnected etc. although this would be unusual. Alternatively the starter solenoid could be burnt out, jammed etc but this is also not very common. Not sure whether the starter solenoid circuit has a (large) fuse in it. Need to check fuse box under the hood in the black box at the rear of the engine compartment.
Most likely cause is that you have an almost dead battery.
Stuart
damone6969
Apr 7, 2012 03:09 PM
gvdipaolo
Dec 18, 2007 07:50 AM
techworks
Nov 21, 2006 01:51 PM
jddumas
Feb 20, 2004 11:29 AM
jddumas
Feb 19, 2004 01:15 AM
