-   -   2000 S class sat nav problem (https://mercedesforum.com/forum/general-tech-5/2000-s-class-sat-nav-problem-18346/)
sonic Feb 23, 2007 01:11 PM
Has anyone else found that Comand system is not picking up a signal from the satellites.. and how did you solve it? Great car, little problem as I can use my Palm's sat nav whenI put the receiver on the sunroof visor. Windows on car don't allow signal!
Sprint97 Mar 2, 2007 11:56 PM
RE: 2000 S class sat nav problem
I have a 2002 S430 and the windshield is UV glass. A hand held garage door opener will not send a signal through it except a small 3" x 4" area low on the glass just off center to the right. It is possible your M-B has the UV glass. You may be able to pick up a satillete signal through that small area. Try moving the receiver to that area.
sonic Mar 3, 2007 04:15 AM
Many thanks Sprint, will give it a try today. Now my car (which is brlliant in every other way) has developed a problem with its Air Suspension. The warning signal "Car too low" comes on with 5 people on board, so its of to MB to get the problem sorted. I will let people know what the cause is when it given back after a small (?) donation to MB.
Sprint97 Mar 3, 2007 02:42 PM
There is also an area in front of the inside mirror the door opener signal will work. It also is small. You might also try that area.
