-   -   1990 300SE Does Not Crank (https://mercedesforum.com/forum/general-tech-5/1990-300se-does-not-crank-5522/)
fcasadon Jul 9, 2005 06:17 PM
This morning the starter would only click. Moved it to Nuetral and somewhat better - but only chattered. Tried to jump the car with a portable battery charger - starter only clicks.
Neutral safety switch problem? Where is it located on the 300SE? I will clean the ground cable as well.
fcasadon Jul 9, 2005 11:08 PM
RE: 1990 300SE Does Not Crank
The battery was the culprit. The lights dimmed as I tried to crank the car.
Thanks forum..... .
