1987 Mercedes 300D lift pump & injector return line
Old Apr 19, 2008 | 08:14 PM
steigermeister's Avatar
Default 1987 Mercedes 300D lift pump & injector return line
The return line from the fuel injectors is attatched to the diesel filter and I I'm wondering if it sends fuel back to the filter for some reason. Also where on the engine is the lift pump located?
Old Apr 20, 2008 | 04:33 AM
lwbrewer's Avatar
Default RE: 1987 Mercedes 300D lift pump & injector return line
Left side front under the injector pump is your fuel pump. Fuel comes from the tank to a small plastic pre filter to a regulator to the oil filter for warming then to the fuel pump. Their it goes to the filter canister then to the injector pump, to injectors, return line to the filter hub. From there excess fuel is returned to the tank so it can circulate. Diesels send excess fuel to the injectors where they regulate the fuel into the cylinders so when you step on the fuel petal your not waiting on the pump to supply more needed fuel extra fuel is returned which filters all the fuel and also warms the fuel in the tank. Hopefully this helps.
87 300D
rfourt
Sep 10, 2011 11:26 AM
pkbell
Jul 18, 2010 05:01 AM
boblo_home
Jun 2, 2008 08:58 PM
bahamutsd
May 4, 2008 08:01 PM
technoreid
Feb 21, 2008 04:42 PM
