-   -   1985 380sl Idle Speed Too High With Warm Engine (https://mercedesforum.com/forum/general-tech-5/1985-380sl-idle-speed-too-high-warm-engine-4891/)
tx380sl May 22, 2005 11:00 AM
With a warm engine idle speed is 900 rpm. Electronic idle speed control unit has been changed, 16 degree centigrade temperature switch checks ok, idle speed control valve checks ok. Any idea what could be causing the high rpm?
sleepwalker May 23, 2005 12:12 AM
RE: 1985 380sl Idle Speed Too High With Warm Engine
try adjusting the speed via throttle body plate
