| SAWYERFACE |
Feb 26, 2010 01:02 PM |
1983 300sd smoking and cutting out!!!
I have a 1983 Mercedes 300SD. When the car warms up it will only go about 10-15 miles an hour up a hill. When I go uphill it seems like I am hitting the brakes as the engine cuts out. It works better the less I push the pedal. On flat ground if I have the pedal pushed more than halfway down the engine cuts out. At the same time it does this it will smoke out of the exhaust. The car takes a while to start after the glow plug light goes out. I have changed the glow plugs, and the fuel filters but it has not helped. Does anyone have any suggestions that might help?
Thanks, Dan
