-   -   190d electrical problems (https://mercedesforum.com/forum/general-tech-5/190d-electrical-problems-13844/)
natdavauer Aug 21, 2006 09:55 PM
I just got a 190d and it seems to have general electrical problems. (my most despised of car problems) I don't know if they are separate issues or if there's one fix that gets everything back to normal. I'll list some of the problems. Maybe they are common in this model.
Power antenna doesn't go up.
Front passenger power window doesn't work
Moonroof doesn't work (I hear the motor running in the trunk)
Cruise control works intermittently
Climate control: the fan comes on randomly as does the heat. you have to pop back and forth between settings to shut off the heat and then back to a different setting to shut of the fan. back and forth over and over.
