190D Door Panel Removal
I searched for this and didn't find what I need so,
I need to remove the front door panel for window replacement. I took the 10mm bolt out of the pull handle and removed the trim from the door latch. I'm trying to be careful so I don't break anything. With gentle upward pressure, the panel wants to move but it's tight where the power seat switch assembly is. Is there a hidden screw I'm missing, or is there a "trick"?
I will also need to remove the rear panel, too. Any mystery there?
Ken
Ken
