180E Clutch Low Pedal
I have recently purchased a 1993 180E with 188,000km. </P> The clutch engages only about 1" off the floor. I have read various posts that suggests that this is due to air in the system. </P> I had to remove the slave cylinder to unblock the bleed screw... a rotten job!</P> I have bled the system from above and "reverse bled" it from the front disc caliper with no success.</P> Can anyone suggest a solution?</P> Thanking you!</P> Peter</P> |
