160 Wont start
Hello,
A friend of mine has a A160 that sometimes won't start. When you put the key in and turn it you can hear the fuel pump start, but whan you turn it to engage the starter nothing happens. No sound No anything. Then a while later it will start and run fine, you can even bump start... It is just as if something beyond the key dies for a while then sorts its self out again. I have had to top of the battery/fuse box and all seems in order Mercedes have been to see it, run diagnostics on and but the fault has gone away, and no reported problems. Any ideas please, also does anyone have a softcopy of a wiring diagram I can download. Many thanks in advance Ian Knight |
RE: 160 Wont start
any messages in the ICM?
[IMG]local://upfiles/1/6D280B05AD644A948305C8AF8E95BE55.jpg[/IMG] |
RE: 160 Wont start
Sleeperwalker,
Thank you a 1000 thousand time for the diagram on the 160 starter circuit it will be a great help. Also do you know where in the car Merc have put the starter motor. We have looked on the outside of the engine as nomal be we can not see it. Again many thanks Ian |
RE: 160 Wont start
i can't blame you if you cannot see it because........
.... you have to LOWER the engine together with the front axle!!! [IMG]local://upfiles/1/3703EF5C63F6458EB34D32949C35D908.jpg[/IMG] |
| All times are GMT -5. The time now is 08:05 AM. |
