-   -   03 E500 Air Suspension (https://mercedesforum.com/forum/general-tech-5/03-e500-air-suspension-51110/)
ERIC WOODS Mar 31, 2012 05:49 PM
got an E500 rear l/h airbag went bad replaced both rear airbag springs new compressor & compressor relay, car will not inflate airbags or lift rear anyone ever come up with this problem in the past,dont know what to do next
chassis221 Mar 31, 2012 06:12 PM
might have to clear codes first. might need MB computer to clear codes. and activate air suspension. can you hear the airmatic pump running?
ERIC WOODS Apr 1, 2012 03:52 PM
03 e500 air suspension
no airmatic pump does not run something seems missing as afar as juice to power pump,can make the pump run by powering directly have checked relays & fuses we did replace the airpump relay with genuine MB part the air springs are identical to what came off it Bilstein's
