-   -   01 2014 WIS ASRA install problems (https://mercedesforum.com/forum/general-tech-5/01-2014-wis-asra-install-problems-54635/)
Rod Puckey May 4, 2014 11:56 AM
1 Attachment(s)
Hello,
I hope that someone can help me. I have bought a copy of 01-2014 WIS ASRA from ebay and it has turned up on 2 DVDs.
This is supposed to be a full install and being on only 2 discs is surprising.
I am also having massive problems with installing it on a Windows 7 64 bit M/C.
It will not run from Autorun, so I could do with some assistance on what to run and in what order. I have tried to add screen dump of the route to the setup file I have used, but they are too large. I have added the IM log file that shows the failure details.
I ran the setup file in the ewa folder as a first step.
I'm sure that it will be a simple reason, but not one that I can see.
It looks like there is a pre installed version, but I have used the "CleanEWAIinstallation" application to delete everything before I start.
Am I missing something, but it looks like I should delete / uninstall something else, but don't know what.
Any help would be appreciated. I've a small leak in the coolant system and need to access the WIS to find the details of how to get at it.
Many thanks in advance for the help.
Rod Puckey May 4, 2014 12:05 PM
3 Attachment(s)
Ok, I am new and only just found out how to add Pics.
These are the screen dumps I spoke of above.
N_Jay May 4, 2014 06:24 PM
The one I got a couple of years ago gave me fits getting it to run.
Then all of a sudden on a reinstall it ran well (but SLOWWWWW)
Rod Puckey May 6, 2014 03:46 PM
If Only
I think that I could suffer slow, if only I could get it to run.
