"Clicking" Sound from heater?
Old Dec 7, 2005 | 04:39 AM
ZoomNTater's Avatar
Default "Clicking" Sound from heater?
I have a '85 190 E and when I have the heater turned on there is a clicking sound coming from what sounds like the passenger side, in the dash behind the vent. Now, when the temp guage is turned up all the way there is no noise, but if I lower the temp...a clicking it will go. It doesn't do it all the time and the clicking stays at the same noise level. Any ideas of what I should be looking for or where to even start? Thanks for your help!
Old Dec 7, 2005 | 05:45 AM
sleepwalker's Avatar
Default RE: "Clicking" Sound from heater?
locate it first as near as you could.
it can be the vacuum element.
Old Dec 7, 2005 | 01:15 PM
buelltorque's Avatar
Normal operation for the heater valve. closed during cooling, wide open at full heat, pulsing when regulating warmer temperatures, hence the pattern you are hearing.
afu
Feb 10, 2008 05:15 AM
howmanyismany
May 24, 2007 03:17 AM
thechangster
Sep 29, 2006 03:04 PM
noregret4life
Apr 26, 2006 08:14 PM
moonbike
Jan 5, 2006 08:40 AM
