how to turn up PES 5 MW injector pump
i keep hearing about turn up the boost and turn up the injector pump but no real details or instructions.we are putting a OM617 952 into an F-150 using
the ford clutch assembly.flywheel and starter with the mazda 5-speed.finishing welding out the motor mounts and the exhaust system(stock mercedes 300D with small alterations)then it comes out to have the oil drain relocated.the stock 300D radiator and condenser are in the F150 now.so need to know how to hot rod this puppy. loveatcha,4est |
