Stopping Fuel
How do I keep the injection pump from continuing to pump fuel while I am doing a compression check?
Andrew |
RE: Stopping Fuel
Got it figured out. Lever with stop on it pushed to the valve cover direction.
Andrew |
RE: Stopping Fuel
If you have the same diesel that I have, just push the manual emergency engine shut off switch. Im not sure exactly how it goes about tis business, but it shuts the engine off without ruinging/damaging it. You may want to try it. Its location shoudl be in your car's manual. Its jsut a red lever on the engine that says "stop".
I think the way it goes about is cutting pressure to the injectors. Im no expert or mechanic though. |
RE: Stopping Fuel
1977 300D ,Engine continues to run after switching off,How do I repair this problem other than using manual stop .
RE: Stopping Fuel
What is the correct procedure to adjust the fuel stop solenoid?
