Recommended Air Filter 1983 300TD W123?
Old May 9, 2015 | 04:51 PM
handygeek's Avatar
Default Recommended Air Filter 1983 300TD W123?
Prices from $10. - $64. for a replacement air filter:
83 1983 Mercedes 300D Air Filter - Air Intake - Beck Arnley, Fram, Hastings, Hengst, K&N, Mahle, Mann, WIX - PartsGeek
Which should I buy and why, please?
Just acquired this for our son's 18 mile daily commute and already have lots of things to repair.
Thanks in advance for informed-advice.
Old May 10, 2015 | 02:35 PM
handygeek's Avatar
Thanks!
Will see to this asap.
Old May 29, 2015 | 12:22 PM
handygeek's Avatar
Finally got Benz out of garage. Local shops don't seem to stock matching air filters - so I'll order one.
This is a '83 300TD.
Just went out to inspect the whole air filter assembly & after removing the nut & clips the cover refuses to come off.
There's evidence of prying on the back edge of the assembly - is it common that the lid may need to be forced?
I don't want to damage anything ...
Old May 29, 2015 | 06:12 PM
handygeek's Avatar
OK, so something must be jammed ... flat prybar to the rescue!
Old May 30, 2015 | 10:42 AM
handygeek's Avatar
Does this air filter assembly look original to you?
It has 3 bolt holes in the bottom and only one is being used.
Yes, that is a small puddle of oil in there ...
I read about a separator that can be added to drain-off the oil thrown-up by the engine - any recommendations re. that, please?
Attached Thumbnails Recommended Air Filter 1983 300TD W123?-benz300td83-001.jpg   Recommended Air Filter 1983 300TD W123?-benz300td83-004.jpg   Recommended Air Filter 1983 300TD W123?-benz300td83-007.jpg
Old Jul 8, 2015 | 02:26 PM
1985W123's Avatar
I prefer the MANN Air Filter. They are very good quality, reasonably priced, and do the job efficiently.
StickyBenz
Feb 1, 2012 06:24 PM
parasuco
Mar 13, 2009 02:21 PM
UKMercNut
Dec 17, 2008 12:24 PM
gharnden
Sep 27, 2007 09:07 PM
BenzoDJ
Sep 12, 2006 01:28 AM
