Recommended Air Filter 1983 300TD W123?
Prices from $10. - $64. for a replacement air filter:
83 1983 Mercedes 300D Air Filter - Air Intake - Beck Arnley, Fram, Hastings, Hengst, K&N, Mahle, Mann, WIX - PartsGeek Which should I buy and why, please? Just acquired this for our son's 18 mile daily commute and already have lots of things to repair. Thanks in advance for informed-advice. |
Thanks!
Will see to this asap. |
Finally got Benz out of garage. Local shops don't seem to stock matching air filters - so I'll order one.
This is a '83 300TD. Just went out to inspect the whole air filter assembly & after removing the nut & clips the cover refuses to come off. There's evidence of prying on the back edge of the assembly - is it common that the lid may need to be forced? I don't want to damage anything ... |
OK, so something must be jammed ... flat prybar to the rescue!
3 Attachment(s)
Does this air filter assembly look original to you?
It has 3 bolt holes in the bottom and only one is being used. Yes, that is a small puddle of oil in there ... I read about a separator that can be added to drain-off the oil thrown-up by the engine - any recommendations re. that, please? Thanks |
I prefer the MANN Air Filter. They are very good quality, reasonably priced, and do the job efficiently.
