Primer Pump
I have gained much info on this forum now I need a question answered please about my 83 300D.My primer pump is leaking. How do you go about repairing it or removing it. Is there arepair kit. Thanks
RE: Primer Pump
I read recently that the new style is not suitable for veggie oil and other thicker fuels.
________ LEXUS GS SPECIFICATIONS |
RE: Primer Pump
It was dieselgiant.com - I just checked. the old style is also quite a lot cheaper. I like the way it can be locked down also (mine leaks a bit when pumping but not when screwed down), not sure if the new version can do that.
________ Anemia advice |
RE: Primer Pump
ORIGINAL: ForcedInduction Being able to lock down has no real function other than personal preference. The new version is spring return so all you have to do is push it. mine leaks a bit when pumping but not when screwed down ________ Ram 50 |
RE: Primer Pump
ORIGINAL: ForcedInduction ORIGINAL: paddo How do yo know the screw down has no function? ________ Extreme q |
| All times are GMT -5. The time now is 08:13 AM. |
