Power Window Failure
1982 240D - I've lost power to my front left and right rear power windows. Fuse at cowl is good. Anyone know of a relay or some other thing to check in order to track down the problem? The right front and left rear windows work.
I've heard ofdual-diagonal circuits for brakes but this is ridiculous. [sm=WTFsgign.gif]
OK, a lesson learned here. Even though the voltage tester showed 12V at both sides of the fuse there was still a hairline crack in the fuse element. Enough metal was still there to carryvoltage for the tester but not enough to operate the windows. When I removed the fuse it fell apart in my hand.
So, always remove ceramic fuses for physical inspection when electrical problems are encountered.
lxshk
Aug 7, 2008 08:28 PM
