-   Diesel Discussions (https://mercedesforum.com/forum/diesel-discussions-33/)
-   -   Power Steering Fluid, special or not? (https://mercedesforum.com/forum/diesel-discussions-33/power-steering-fluid-special-not-7362/)
JC300SD Oct 18, 2005 01:41 PM
The 85 300sd I will be getting is doing some "groaning" around the driver's side wheel when turning and sometimes straight. I noticed the power steering was fluid was a little low. Does it use some special euro formula or is it just normal power steering fluid? I would appreciatie any help.
JC300SD Oct 18, 2005 04:11 PM
RE: Power Steering Fluid, special or not?
I don't mean to be a pest, but I really need to know the answer to this. I am going to be looking at this tonight. Thanks
Benzbob Oct 18, 2005 11:55 PM
OK, two people need answers..........First, realize that there is a filter within the power steering pump.....should replace......second, DO NOT put automatic transmission fluid back in as replacement..(older MB's are sensitive) (plays with seals) use only -power steering fluid- as bought in auto parts stores, or go to the dealer!
Change your brake fluid too.............every other year......ya!
JC300SD Oct 19, 2005 10:15 AM
Oh well, I put ATF fluid in as described in the owner's manual and Hayne's manual. I did not see a filter in the resoivor. Where is it?
81 300 CD Jun 3, 2006 11:28 PM
if you remove the fluid in the pump reservoir by any means available to you the filter is at the bottom. usually held by a press nut or a regular threaded nut.
blhfla Jun 5, 2006 12:23 PM
If you are concerned about PS fluids, you might try VW PS fluid. Their's is a special mineral formula that they claim MUST be used in VWs (you cannot use common PS fluid in them).
