oil problems
Old 12-01-2008, 09:44 PM
Gagswolf's Avatar
Default RE: oil problems
hings first lets get her started
  #12
Old 12-03-2008, 02:43 AM
merc240d's Avatar
becasue like forcedinduction says its a waste of money
  #13
Old 12-03-2008, 02:22 PM
raffo's Avatar
Sir! Yes Sir!!! Let us help, hope and pray that all goes well with "Heidi" that she may be resurrected.
Gagswolf, all the best eh.
  #14
Old 12-04-2008, 01:56 PM
Gagswolf's Avatar
It is the neutral switch!!! Ican get her to turn over in neutral, will get underneath latter to adjust that, still nothing won't fire up! Cleaned the injectors just p/u a new fuel filter thats tomorrow,does it make a difference in this car if the air intake is not on/ connected to the cute little turbo? I just figured I'd ask it's not on now! I bipassed the fuel tank and am useing the set up for the "diesel purge" with a 1 gal fuel can and i primed the system, should fuel come out the manual pump or not?sould I pull offthe fuel lines to the injectors? I'm kinda stuck no progress lately!
  #15
Old 12-09-2008, 01:17 PM
Gagswolf's Avatar
Well to give eveyone a update... "Heidi" still hasn't started, changed the fuel filters, all the glow plugs get real red at the tips, pulled all the injectors and cleaned them out/off, new return lines, but now I think the starter or the starter solenoid is done for. Turn the key and get nothing, not the neutral switch, not even the clicking like before. I am getting 12-14 volts to the starter solenoid. Is there a way to tell if is getting the juice while the car should be turning over? I got a couple if 45degree days and would love to get her going!!!
Any and all help would be great. If bad where could I p/u one "cheap".
  #16
Old 12-14-2008, 11:22 PM
Gagswolf's Avatar
Hiedi Lives!!!!!!!!!
I pulled the starter and took it apart, there was something shorting out, p/u a new one today. She went right in and 1/2 hour of this and that and a spare set of hands she ran!! Once she was running let it run for about a hour. Ran fuel injector cleaner the whole time.
So thats the good but man do I have one heck of a smoke machine!!! Does anyone know how much back pressure is susposed to come out of the top ofthe block?Tomorrow will do the valve gaps and I also have a leaky injector so thats on the plate too.
THANK YOU for all of you help guys!!
  #17
Old 12-15-2008, 02:00 AM
raffo's Avatar
Great! Congratulations! Now, you can truly say, Merry Christmas and a Happy, challenging New Year.
Naki
06-25-2009 02:13 PM
MarkKBK
04-23-2009 04:47 PM
j.barnes
07-13-2008 11:19 AM
natdavauer
08-22-2006 04:20 AM
mbrown400
04-03-2004 02:42 AM
Quick Reply: oil problems
