New to forum, first time Mercedes owner
Old Apr 24, 2010 | 07:21 PM
SFLizbeth's Avatar
Default New to forum, first time Mercedes owner
Hi all
I'm a newbie, I just purchased my first Benz last week. It's a 1980 300 sd turbo diesel with 230k miles. The interior and exterior need a little work but the engine is sound, it starts on the first try and the ride is smooth. Overall, it's in pretty good shape, it needs new paint, but there is very little rust on the body. I plan on starting to restore it little by little. I am the third owner, the last guy had it for 15 years and I have a good amount of the original paper work.
I do plan on getting a new paint job and working on the upholstery and interior.
The previous owner had a cd of the electrical schematics, are there any other items or ideas that would be helpful to a newbie?
Many thanks for any help/suggestions.
Liz
Old Apr 25, 2010 | 10:59 AM
Diesel9112's Avatar
Check the Rubber Boots on your Rear Axles for cracks or leaks.
Check the Rubber Flex Discs on your Drive shaft.
Ceck you Rubber Oil Cooler Hoses for leaks
Check to se if the Oil Coolers Hoses are getting close to your Power Steering Belt; if so it could mean the Motor Mount is collasping (you guessed it made of Rubber). The Belts have been know to cut through the Hose and cause a loss of Oil and Oil pressure.
So you see the trend here 20 something year old Rubber parts may be reaching the end of their life and must at least be checked. You Front Control Arms also are mounted on Rubber Bushings.
Becareful not to lean on the large Vacuum Hose/Tubeing that goes from the Vacuum Pump to the Brake Booster as the plastic nipples easily crack off.
The Valves need to be adjusted on these Engines.
Old Apr 26, 2010 | 11:53 AM
SFLizbeth's Avatar
Default Thanks for the information
Hi Diesel-thank you for the checklist. I plan on getting started this weekend, the list is very helpful!
Kind regards,
Liz
Deaj
Aug 3, 2014 05:16 AM
SFLizbeth
Apr 24, 2010 07:05 PM
coolatula
Nov 2, 2008 09:15 AM
hmlcc
Aug 27, 2006 01:24 PM
AZC230KOMPRESSOR
Jun 28, 2006 05:14 AM
