need some advice on my diesel
Hello Guys
where to start, i own a 85 300D 3.0 and a 93 300D 2.5 my plans was my 85 i had injector sent out to get upgraded and my pump as well recieved my injectors , havent seen my pump as of yet . was planning on a full build had a 700r4 which was going behind it and all my 93 havent done more than bpu upgrades. had my injectors sent out to get worked on havent seen them , same guy. yea i know i have to find him. but my question is can the injector from my w123 fit my w124? i was planning on installing a HY35 not looking to get super power has anyone really gotten power and know what steps i should do. ive seen the video and all and know that they can make power im not trying to get to radical, just love this car, and would like to get 250hp to 300hp safely out it, if possible. so if there someone that could give me some pointers or get me moving in the right direction, i would be appreciative. love to get my car out this spring. |
The easiest way to tell concerning the Injectors is that if the 85 300D is a US turboed model the Injectors can only be used on another turbo model.
The 93 has different Spray Nozzles inside of the Injector and I do not think the outside physical dimensions of the Injector are even the same. From the pic I looked at the 93 has threads at the very bottom of the Injector while the 85 has theads about 1/2 inch from the bottom of the injectors. I would go to the parts site that you like and look up the Injectos for both. If the part numbers are different than the Injectors cannot be swappped. When I looked the up the 85 300D used NA31X Injectors and the 93 used NA35X Injectors (also the pics looked different). This would tell me they cannot be swapped. |
