Need a k2 spring piston for 190d 2.5 Turbo
My green piston is broken. Does anyone know where I can find a used or new one or anything that could replace it?
Thanks, Paul |
The Mercedes Dealer.
I do not know if there is a Superior Shift Kit for your year and model. If you are going to shop around you might need to know your Transmission Number; the Dieselgiant web site has a pictorial on where to find it. |
Thank you for your reply but the dealer does not supply that part unless you purchase the entire valve body. The shift kit does not include the piston.
You might try a reputable transmission rebuild shop, they might have sources other than the dealer. If nothing else, get a rebuilt valve body.
From what I could find a Rebuilt Valve Body is going to cost more than an used Transmission would.
The cheapest way to go would require a lot of luck. That would be to find a Vehicle at the Junk Yard that has the same Transmission (I think it is a 722.414; the guy who started the thread has never said what transmission his car has) or really lucky would be a late model 722.3** Transmission. |
At least a used tranny (if you can find one) would have some hard parts you might need later
Thank you for your help!
