Need Advice
RE: Need Advice
I think you mean the air cleaner is shaking. Your car, if it's a diesel 300SD does NOT have a carburator. It's normal for the rubber bushings that hold the air cleaner box to the brackets to break. Open the air cleaner top (4 clips and one 10mm nut). You should be able to see the top of the bushings where they come thru the air box there are 3 of them.
BigFP
11-09-2004 10:18 PM
